This command removes the cos-index from the configuration when no attribute is entered or if the last one is unconfigured.
| cos_index | Class of Service index value. |
| qosprofile | QoS profile. |
| ingress-meter | Ingress rate-limiter meter. |
| replace-tos | Replace TOS value. |
N/A.
Use this command to remove the cos-index from the configuration.
unconfigure cos-index 50 unconfigure cos-index 51 qosprofile ingress-meter replace-dot1p unconfigure cos-index 52 qosprofile unconfigure cos-index 52 ingress-meter unconfigure cos-index 52 replace-dot1p
This command was first available in ExtremeXOS 16.1.
